Tillig ICE digital
shimofott
Atlanta USA
Hallo TT Freunde, ich habe eine Suche zu diesem Thema durchgeführt, kann aber nicht eine Lösung finden. Ist es möglich, einen Decoder an ICE hinzufügen, ohne mit TE-2?
Vielen Dank!
Hello TT friends, I have done a search on this subject but can not find a solution. Is it possible to add a decoder to ICE without using TE-2?
Thank you!
@shimofott:
According to Tilligs web site, their ICE does have a NEM interface. So any NEM651 decoder should work fine.
Andi
that's right.
Additionally please allow me some remarks.
To have the ICE running smooth the decoder of your choice should have a very good, sensitive and fine tunable back-EMF-compensation.
I would suggest to have a look at Zimo's decoders. They have a very good motor regulation algorhythm and are state-of-the-art.
You have enough space to mount the decoder, so feel free to implement a larger decoder wich allows a little higher max current.
Here is a link to the manual of the actual new decoder generation:
http://www.zimo.at/web2007/pdf/MX620MX630MX640E.pdf
A critical point on the Tillig ICE is the electrical connection to the track. I recommend to add additional connectors. I described this here when I installed DCC decoders in my ICE in year 2002 (but replaced the decoder with a better one so far later on):
http://home.arcor.de/steffen.engewald/tt-bahn/digital/ice/umbau_ice_tillig.html
On the engineless side a simple function decoder or an old leftover TE1 would do their work fine - if you mount the red/black cable connection to track reverse you don't need to change direction in CV29.
different circuit boards
Hi^^,
thats not the complete truth. I dont know, which Version your ICE have. Is there a NEM (european modelltrain standarts) plug in?. Sometimes you have a circuit board with a Plug for the 6-pole decoder. Sometimes you have a circuit board with solder points to solder the decoder. Please discribe which Version do you have. I think you have the 2nd Version...
greets Tom
Hi^^,
greets Tom
Genau.
Ich habe keinen NEM-Stecker auf mein Modell. Es ist eins der älteren Boards, Löten eines Decoders erforderlich. Ich versuche herauszufinden, wo auf der Platine des Decoders Terminals verlötet werden sollte.
Prost!
Exactly.
I do not have a NEM plug on my model. It is one of the older boards that requires soldering of a decoder. I am trying to find out where on the board the decoder terminals should be soldered.
Cheers!
@ Steffen E,
Ich werde zur Änderung des elektrischen Tonabnehmer aus der Drehgestelle so ist es kein Problem sein sollte.
Es ist einer der folgenden:
Ist´s a kind of this board ? I can´t imagine, ´cause its a board with a included decoder. greets Tom
Edit: I think its a board like this one, isn`t it ?
Edit: Number 1: this part must be broke out of the board.
Number 2: on this pads you must solder the decoder
Es ist wie mein Bild nicht aber die Lenz. Nur die regelmäßige Tillig - ich habe nicht ein Bild, dass man.
Der Vorstand wird in Ihrem Beitrag nicht ein Problem für mich - (leicht Löten).
Danke.
Danke. Ich bin bei der Arbeit gerade jetzt (ich bin in Amerika), aber ich werde heute Abend ein Bild zu machen, wenn ich nach Hause komme.
Thank you. I am at work right now (I am in America) but I will take a picture tonight when I get home.
Die abgebildete Leiterplatte ist eine TE1.
Da geht mit löten nur mit hohem Aufwand etwas zu machen.
Entweder die TE2. Oder besser die hier: http://www.modellbahnshop-sebnitz.e...3&r2_id=5375&artnr=390570&pager2=0,,0,0,0,0,0,
Da ist dann die freie Wahl des Decoders gewährleistet.
Wer untersetzt :boeller: bitte mal.
Ich "opfer" mich mal
There is only with great effort and solding something to do possible.
The better way is, that you´ll take the TE 2 or this one: http://www.modellbahnshop-sebnitz.e...3&r2_id=5375&artnr=390570&pager2=0,,0,0,0,0,0
If you take the product which is shown at the link than you have a free choise wich DDC-Decoder do you´ll buy.
greets Tom
as I understood the photo shows the TE1 (by Lenz) board which allreads has an integrated DCC decoder (without back-EMF-compensation, type like Lenz LE077XF) but this is not the board in the ICE, only one with similar physical dimensions.
So you will find the standard Tillig analog board inside (if you bought a new ICE from a modell railroad dealer), and can:
1. solder a decoder to the pins 1 to 6 (refer to the decoder's documentation, it's easy)
2. if it is a newer one which allready has the NEM 651 female plug, then you also could plug in a NEM 651 compatible decoder. In this case you should buy the version of decoder with NEM651 plug or solder one on the cables.
For both cases you need to brake out the little analog part of the board, as described in the Tillig manual.
For any other cases you will not need a special platine board, there are only some wires to connect: left and right track to decoder's black and red cable and to the 2 cables from the ICE electrical coupling. Motor to decoder's gray and orange cable. Yellow and red LED's pads to decoders white and yellow cable, LED common plus pad to decoder's blue cable.
And in the case you will find a TE1 inside (don't know if you bought the ICE as used part) then use it as functional decoder for the LED lights in the motorless end.
If there are any remaining questions please feel free ...
well if you think it is speculation:
yes, I don't know which of the named boards is inside
no, it's no speculation. tommy, you made photos on the 2 kinds of analog boards, so it's easy to determine based on them what kind of board is inside.
How to proceed - that's what I've written.
So the only question is: which of them ... :allesgut:
Nevertheless, you'll allways get 197 different answers on a question in a board :)
good night to all
Hallo alle und danke Ihnen nochmals für die Antworten. Ich öffnete das Modell und das Board ist der Lenz-Version. Ich glaube nicht, es war, weil es nicht mit der digitalen (ich gebraucht gekauft und nichts war von dem Verkäufer über digitale erwähnt funktioniert). Ich habe versucht, jede Adresse, aber niemand ist zu Hause. Also entweder das Brett muss zurückgesetzt oder es ist schlecht.
Sorry, Sie mit meiner Verwirrung zu verwechseln. :wall:
Hello all and thank you again for the responses. I opened the model and the board is the Lenz version. I did not think it was because it does not work with digital (I bought it used and nothing was mentioned by the seller about digital). I tried every address but nobody is home. So either the board needs reset or it is bad.
Sorry to confuse you with my confusion.
ICE Digital
Ich habe bei meinem die Platine komplett entfernt, und einen
Decoder direkt angelötet, die Beleuchtunsplatinen verbleiben dabei
Triebkopf. In dem nicht angetriebenen Triebkopf ist ein Tams
Decoder für 5,95€ zum ansteuern der Beleuchtung zuständig.
Ist auch eine möglichkeit bie Digital.
grüße
Dieter
Hallo Digitalexperten,
hat schon einmal jemand versucht mit der LT10 Lichtleiste von Kühn den unangetriebenen Triebkopf des ICE auszurüsten? Immerhin ist die Leiste noch billiger als ein einzelner Digitaldecoder und man könnte die Lichtleiste als Führerstandsbeleuchtung verwenden (gekürzt natürlich). Zwei Funktionsausgänge für die Stirnbeleuchtung sind auch vorhanden! Soweit erstmal mein Überlegungen.
Frage an die Experten: Kann ich die LT10 für mein beschriebenes Szenario verwenden?
Gruß shorti
PS: @dieter: Welchen Decoder hast du denn verwendet? Ich konnte keinen Tams Decoder für ~6€ finden.
