Modellbahn nach amerikanischem Vorbild
Noch zwei US-Bausätze. Eine Diesellok DD-40 und eine Dampflok.
Die DD-40 wurde ja schon weiter oben erwähnt.
Bei der Dampflok ist leider keine Anleitung dabei, so dass ich nicht sagen kann welche Lok da Vorbild ist. Wird bestimmt auch spannend, die ohne Anleitung zusammenzusetzen.
Bei der Dampflok sollte soetwas wie eine "Berkshire"(2-8-4) bei rauskommen, hier allerdings mit etwas größerem Tender und Speichenrädern :DSC01749.JPG
I unexpectedly received a package from Pennsylvania. Inside was an ALCo C425 case from CMR Products.
Unfortunately, the quality isn't very good. The side panels warped inwards during printing, and the frame isn't straight when viewed from above. While the steps/handles on one end were printed very well, they're too thin. I think holes made from bent wire would be better. Nothing more than the body is included. So, you'll need to get creative with the tank, bogie covers, and handrails yourself.
Anhang anzeigen 559730Anhang anzeigen 559731
Now for the good news. The resin is very stable and not particularly brittle. The supports are quite easy to remove. There's ample space inside for the chassis of the Lok-n-Roll GP30. The millimeter difference in the distance between the bogie centers is barely noticeable. The bogies are the 23mm ones from Halling. According to the prototype, they would be 23.7mm. One could use the 24mm ones from Halling, but then the existing 23mm bogie sideframes wouldn't fit. The height of the body can still be adjusted; I placed a 0.7mm thick strip of plastic on the chassis. This makes the locomotive look appropriately tall. I still need to check the space and position for the couplings.
All in all, a great model, with a few minor teething problems in the design and printing. That's my first impression, and many thanks to @areibel!
The print still seems to have orientation problems , despite talk of them using a larger printer. As long as it has to be printed diagonally, I guess it will have such issues.
Man kann ein Objekt schräg oder diagonal im Drucker platzieren, ohne dass man Abstriche in der Qualität befürchten muss. Hier ist CMR Products gefragt ihren Druck bzw. die Kontrolle der Drucke zu verbessern.
I have a C430 from them. Same problems. I doubt they will improve. The diagonal lining affects the hood doors, but these are are incorrect anyway. As they are on the C425.
Das ist schade. Wenn sie ihre Qualität der Drucke nicht verbessern, dann wird kaum einer dort noch etwas kaufen.
The advantage is that their 3-D printing material is sturdy and hard, with a little flexibility. I will try to turn my C430 into a C630.
Mein kanadischer Freund baut nicht nur sich, sondern auch mir eine N2 Consolidation der Canadian Pacific. Da in Spur N vorgesehen ist die Glocke des Bachmann-Modells zu verwenden, das das Fahrgestell spendiert, wurde keine Glocke mitgedruckt. Hat jemand von Euch eine Idee für eine Bezugsquelle einer Glocke?
http://www.trainweb.org/oldtimetrains/photos/cpr_steam/3651.jpg
Das war auch meine Idee. Aber weder bei Weinert noch bei der Modellbahnmanufaktur Crottendorf findet sich etwas passendes. Eine Glocke haben aber beide.
Bei Thingiverse gibt es mindestens ein 3D-Modell einer Glocke.
Von welcher Lok stammt denn Dein Fahrwerk?
Die Herausforderung ist die Halterung der Glocke. Sonst gäbe es auch einfach bei Fischer Modell eine Glocke.
Das Fahrwerk ist von Tilligs BR86. Daher die zweite Frage. Er sucht für die Steuerung eine doppelte Kreuzkopfführung, die BR86 hat eine einfache.
Schau mal bei Bemo nach.
Gibt's bei Bemo auch meist am Messestand an den Drehsäulen.
Manches H0 Schmalspurteil passt auch gut für TT
Hallo TT`ler,
heute soll es mal wieder ein Lebenszeichen vom mir geben. Offensichtlich gibt es doch noch Interessenten zum Thema US.
Meine AMTRAK Garnitur fährt nun schon fast ein Jahr zuverlässig als "Gast" auf meiner Anlage.
Ja ich weiss, man kann da noch einiges besser machen, aber für mich als "Spielbahner" habe ich meinen Zweck erreicht, denn dieser Zug ist nun mal auf TT-Gleisen einmalig. Falls es Kollegen gibt, die Interesse haben, ich bin gern bereit die -stl. Dateien für einen kleine Spende privat zur Verfügung zu stellen.
Die Lok und die Wagen wurden inzwischen auch entsprechend der gefahrenen Kilometer etwas gealtert.
Hier noch mal eine kurzes Video.
Er meint wohl die unlackierten Switcher, welche es mal aus Bausätze gab. Nicht jede SW hat eine Glocke auf der Motorhaube.
